Larvikite Healing Properties
♥ Grounding ♥ Protective ♥ Patience
Larvikite is a member of the Feldspar family. The name originates from the Larvik Fjord region in Norway, where this type of igneous rock is found. It is sometimes called "Black Moonstone" and even "Labradorite", more likely because they are all Feldspar minerals.
Chakras - Base Chakra
Zodiac - Aquarius
Element - Water
Typical colours - dark grey, dark blue to black with a blue or steely coloured flash
Larvikite is a protective and grounding stone. It is cleansing to the subtle bodies and facilitates a strong connection with the energies of Earth, helping to connect with the spirits of Nature. Larvikite stimulates inner visions and enhances our psychic abilities. It allows us to see the past, providing clarity to visions of past life recall. Larvikite can neutralise and cancel spells that are no longer wanted. It repels negative energy. Larvikite increases our security in the strength of our own intellect, stimulates creativity and the exchange of wisdom. Larvikite helps us to see ourselves through the eyes of our higher self. Larvikite teaches patience, and can support when completion and closure to a goal is required. It also helps us to understand and resolve complicated facts and to make decisions that are rational and sober and not based upon our emotions.
Larvikite assists the brain to take in new information more easily. It creates new pathways for knowledge to travel and can open new doors for us. Larvikite can help to make us more adaptable to situations.
Larvikite can help with learning disabilities. It can be used to treat skin disorders and enhances vitality and youthfulness. Larvikite aids in the recovery of strokes and helps brain function. It cleanses and purifies body tissue, harmonises the metabolism and helps with muscular detoxification. Larvikite calms the nerves and will cool and reduce blood pressure.
Descriptions of the healing properties of gemstones are from the following sources:
- "Love is in the Earth : A Kaleidoscope of Crystals
" by Melody (I highly recommend this book);
- "The Crystal Bible Volume 1: Godsfield Bibles: A Definitive Guide to Crystals
" by Judy Hall (I highly recommend this book);
- My own experiences and observations of gemstones.
