Caryl Haxworth ~ Charms Of Light
MENU
How to Wear a Lariat Necklace
A Lariat Necklace is not only beautiful, it is also extremely versatile.  You will find that it looks fabulous with every outfit in your wardrobe and can be worn in many different ways.  The looks below are just some ideas for you to try.
Choose your Lariat Necklace.
Pearl Lariat Necklace
Double up your lariat necklace and wrap it around your neck, bringing both ends to the front.  Thread the ends through the loop (like a scarf) and gently pull to the required length.
Wrap the lariat necklace once around your neck and bring the ends together at the front.  Gently tie in a loose knot.
Put your lariat necklace around your neck, bringing the ends towards the front.  Gently tie in a loose knot as low or high as you like.
Put your lariat necklace around your neck, bringing the ends towards the front.  Holding the ends together, make a loop, then thread the ends through the loop and gently pull through, making a double knot version of the style on the left.
